Date/Time: Mon, 13 Jan 2025 06:22:57 +0000
trouble with indicator volume by price
View Count: 637
[2017-04-12 00:47:53]
User819109 - Posts: 7
Hi i have a problem with the indicator volume by price , I do not have access to all the volume profile , I am limited on all the symbols to 220 days of data volume profile if the historical chart bar period is one day or 40 days in 4 hours for example , however in the graphic setting I can to put than 3000 days to load and in the parameters Of the indicator: number of days calculated in volume profile,also I can put 500 days or 1000 days, I am always limited to 220 days in historical chart .
i have a package 5 and i use the flux : SC Data all service .
thanks for your help .
I send you the screenshot on USOIl for example .
imageCapture usoil.PNG / V - Attached On 2017-04-12 00:47:01 UTC - Size: 135.36 KB - 257 views
imageCapture 2.PNG / V - Attached On 2017-04-12 00:47:09 UTC - Size: 136.08 KB - 238 views
[2017-04-12 17:14:30]
You need to set the Volume Graph Period Type Input Setting to what you require and not to Visible Bars. Refer to the documentation for this Input setting here:
https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_VolumeGraphPeriodType
