Date/Time: Mon, 13 Jan 2025 06:04:33 +0000
save and reinstall
View Count: 675
[2017-04-11 21:06:17] |
User756575 - Posts: 5 |
How can I save Sierra Chart if I want to re-initialize my pc or install it in a new one?
[2017-04-11 21:25:29] |
Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
