Date/Time: Mon, 13 Jan 2025 06:20:44 +0000
Error Code
View Count: 1173
[2017-04-11 16:24:36] |
ElmStreetTrader - Posts: 48 |
Error binding to UDP port 22903. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-04-11 18:21:02
Is this error important? SC still seems to work perfectly. |
[2017-04-11 17:03:41] |
This is not harmful but you do need to resolve it. Set Global Settings >> Data/Trade Service Settings >> SC Server Settings >> UDP Port to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-11 17:05:08
[2017-04-11 17:04:47] |
The prior post has been updated.
[2017-04-11 17:50:12] |
Does it matter which instance I change, FXCM or Amp/Rithmic?
[2017-04-11 17:56:38] |
Set them all to 0.
