Date/Time: Mon, 13 Jan 2025 06:10:08 +0000
Setting the vertical scale height in pixels
View Count: 917
[2017-04-11 01:51:28] |
User553714 - Posts: 184 |
Is there a way that I can set the vertical scale height of the window in ChartRegion = 1 to a set height (in pixels); I have tried playing around with the scale functions like setting sc.ScaleRangeTop, sc.ScaleRangeBottom & sc.ScaleConstRange but they are used for setting the actual scale not the physical pixel height? Regards
[2017-04-11 01:57:04] |
No, this is not supported.
