Date/Time: Mon, 13 Jan 2025 06:14:45 +0000
Bad Tick data
View Count: 627
[2017-04-10 17:44:49] |
User563732 - Posts: 1 |
http://www.sierrachart.com/image.php?Image=1491846152489.png My tick data looks corrupted... My minute data and other historical data is fine. How can I fix this? Thanks, Robert Wilkes |
[2017-04-10 17:49:39] |
Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
