Date/Time: Mon, 13 Jan 2025 05:44:02 +0000
Maxium Bid/Ask Market Depth
View Count: 653
[2017-04-10 17:22:06] |
User624476 - Posts: 33 |
As there have been some changes in the exchanges lately, are there are any plans to allow SC to show more bid/ask order information? It seems the current limitation is 50 levels above/below from the last price price no matter the settings (e.g. chart max depth and DOM max depth all set to 1000) I am specifically referring to the Rithmic Data feed and for example Gold or Crude futures, etc. Rithmic's direct access software (R-Trader) shows LIVE bid/ask depth down to 1180! (current price is 1255). Thanks |
[2017-04-10 17:27:36] |
No there are no plans for this.
[2017-04-10 17:30:08] |
Please do consider this if possible - it could be very useful especially in conjunction with the market depth historical study.
[2017-04-10 17:32:34] |
Eventually this will be supported, but it is not something looked upon favorably because as soon as we do it, it generates lots of complaints because it creates lots of problems from unexpected side effects of it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-10 17:33:00
