Date/Time: Mon, 13 Jan 2025 05:22:27 +0000
Alert not working as expected
View Count: 615
[2017-04-10 14:41:18] |
User976133 - Posts: 38 |
I have a set of charts with a crossover alert. The alert draws an arrow and plays a sound file. It works perfectly on 2 of the 3 charts, but on the third it is not. The arrow draws, but the sound does not play, nor does it show up in the alerts window. But, on the second occurrence of the event, it works perfectly. Any thoughts or suggestions on where to look to get it corrected? |
[2017-04-10 16:46:55] |
How is this Alert Condition implemented? Is it using the method documented here: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
