Date/Time: Mon, 13 Jan 2025 06:18:27 +0000
Bid/Ask Lines
View Count: 3610
[2017-04-10 12:07:46] |
User731667 - Posts: 8 |
Hi, just wanted to know if there is a way to fully extend the Bid/Ask Lines horizontally across the chart? Under The Chart tab I have enabled show bid/ask lines but it only gives 2 very short red and green lines on the far right of the chart, these are the lines I would like to extend across the chart? Thanks
[2017-04-10 14:15:38] |
TH.555 - Posts: 38 |
Hi, Chart Settings > Advanced Settings 2 > Draw DOM Graph on Chart > Show Spread > Width in Bars
[2017-04-10 17:10:09] |
You can use the DOM Graph instead: http://www.sierrachart.com/index.php?page=doc/TradeMenu.html#DrawDOMGraph And then you can set the width of it in bars as you require. Also have a look at the Current Price Line study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s123 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-10 17:11:07
[2017-04-11 08:51:15] |
Thanks for both responses, much appreciated. I think The Current Price Study is the best for me, I have been able to get the price line to extend Far left chart to far right chart using forward projection bars and also using the displacement in the subgraphs area. Thanks again
