Date/Time: Tue, 22 Sep 2026 15:09:39 +0000
fonction ascil to recover the numbre of the chart
View Count: 1121
| [2017-04-10 11:36:03] |
| User210074 - Posts: 63 |
Hello, Do you have a ASCIL function to retrieve the chart number? I have this to recover the symbol of the chart. SCString Futures; Futures.Format("%s", sc.Symbol.GetSubString(4,0).GetChars()); |
| [2017-04-10 14:13:25] |
I find the fonction "sc.ChartNumber"
| [2017-04-10 16:52:56] |
Yes that is it.
| [2017-04-10 19:18:02] |
I test this but I have an error message that I do not understand. I test to write the number in a text file to see if everything is good. SCString Futures; Futures.Format("%s", sc.Symbol.GetSubString(4,0).GetChars()); string IndiceSierra = Futures; int NumberOfChart; NumberOfChart.Format("%s", sc.ChartNumber.GetInt().GetChars());/*L38 here*/ string LinkA{"C:\\SierraChart\\Data\\Temporaire\\"+IndiceSierra+".txt"}; ofstream FileA(LinkA.c_str(),ios_base::app); FileA<<NumberOfChart+" | ";/*<- just to see*/ FileA.close(); C:\SierraChart\ACS_Source\Test.cpp(38): error C2228: left of '.Format' must have class/struct/union Date Time Of Last Edit: 2017-04-10 19:31:38
