Date/Time: Mon, 13 Jan 2025 06:02:35 +0000
No automatic scaling in TPO charts
View Count: 1370
[2017-04-09 09:11:03]
User889191 - Posts: 61
When flipping through different trading instruments TPO charts are not scaling automatically in a acceptable way. Setting Letter/Block Price Increment in Ticks to 0 does not help. E.g. I look a stock chart of Ford(Last traded price 11.23) and Apple(Last traded price 143.34). When TPO chart is linked via quote board and symbol is changed TPO is not scaling nicely. I have then to manually set Letter/Block Price Increment in Ticks to an appropriate size. This is cumbersome. It should be possible to have nice TPO charts when changing trading instrument.
imageTPO_Ford.png / V - Attached On 2017-04-09 09:10:16 UTC - Size: 20.74 KB - 557 views
imageTPO_Apple.png / V - Attached On 2017-04-09 09:10:29 UTC - Size: 18.18 KB - 304 views
[2017-04-10 10:04:35]
You need to adjust the Tick Size for the symbol in Global Symbol Settings. Refer to:
Time Price Opportunity (TPO) Profile Charts: The Effect of Letter/Block Price Increment Setting
[2017-04-10 10:54:10]
I created new symbol for AAPL(SC Data all services) and set tick size to 0.2(20 x standard 0.01). No effect in chart. Please explain how to correctly configure symbol.
[2017-04-10 16:54:51]
You then have to apply the symbol settings to the chart. Refer to the instructions here:
http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#UpdateChartSettingsSteps
[2017-04-10 17:54:27]
Does not work. I applied symbol settings to chart. I have created new chart from scratch and applied TPO study for monthly profile. The chart setting is still the same.
imageAAPL.png / V - Attached On 2017-04-10 17:53:40 UTC - Size: 16.19 KB - 309 views
imageAAPL_How_it_should_look_like.png / V - Attached On 2017-04-10 17:53:58 UTC - Size: 22.97 KB - 274 views
imageAAPL_Symbol_settings.png / V - Attached On 2017-04-10 17:54:05 UTC - Size: 41.84 KB - 295 views
imageAAPL_TPO_settings.png / V - Attached On 2017-04-10 17:54:17 UTC - Size: 48.7 KB - 284 views
[2017-04-10 18:23:10]
We added Symbol Settings for AAPL, and the correct settings were used for a new chart and also when applying them to an existing chart.
How is Global Settings >>Data/Trade Service Settings >> Service set?
Date Time Of Last Edit: 2017-04-10 18:23:23
[2017-04-10 19:58:59]
See attachment.
Private File
[2017-04-10 22:24:51]
This is the reason it is not working.
You need to add the new symbols in the Symbol Settings for CQG FIX Trading.
[2017-04-11 16:03:13]
It is working now. Thanks for your support.
