Date/Time: Mon, 13 Jan 2025 05:22:38 +0000
Tracing Study Dependency Between Charts
View Count: 624
[2017-04-09 01:59:50] |
drywater0 - Posts: 85 |
SC Support, I believe there is a way to identify if a study on one chart is used as an input or feed to another chart. For example, a moving average on a 1 minute chart is used in a calculation on a 5 min chart. Isn't there a notation somewhere on the study settings that displays which other charts depend on it? Can you please provide a link for this documentation? I've read about it before but couldn't find it after searching using different keywords. Many thanks in advance. |
[2017-04-10 10:28:57] |
This is explained here: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.9 You need to select Chart >> Chart Settings for the source chart and look at the title bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
