Date/Time: Mon, 13 Jan 2025 05:15:48 +0000
Copy value in Column J to another spreadsheet column
View Count: 678
[2017-04-08 18:08:11] |
User260310 - Posts: 6 |
In a spreadsheet study, how would I store the value in a column J cell at each bar, in a separate spreadsheet column. For example, I would like column AA to show a running history of cell J10 (open profit/loss) at each bar (AA3 = current p/l, AA4 = p/l at previous bar, etc.) Is this possible?
[2017-04-10 10:23:19] |
Not sure how to do this. However, we recommend looking at the Trade Data Studies instead: Trading Information Windows: Trade Data Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
