Date/Time: Mon, 13 Jan 2025 05:11:32 +0000
Log scale monthly and quarterly charts
View Count: 785
[2017-04-08 16:22:27] |
b3cker - Posts: 34 |
http://www.sierrachart.com/image.php?Image=149166845549.png It seems SC has an issue with Log scale for monthly and quarterly charts |
[2017-04-08 22:08:01] |
It looks fine for us: http://www.sierrachart.com/image.php?Image=1491689204531.png There might be a negative value in the data you are looking at. Re-download with Edit >>Delete All Data and Download. Although we see you have obtained your own data. So there must be a zero or negative value causing the problem. If so we cannot help with that. That is your responsibility to work out. Make sure there are no zero or negative values in any of the chart bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-08 22:36:37
