Date/Time: Mon, 13 Jan 2025 05:38:36 +0000
TRADING SYSTEM FOR FOREX
View Count: 754
[2017-04-07 18:09:39] |
User82615 - Posts: 106 |
HELLO I'M PROGRAMMING A TRADING SYSTEM TO OPERATE IN FOREX , BUT I HAVE A DOUBT : WHEN IN THE ORDER I HAVE TO SPECIFY THE ORDER QUANTITY WHAT MUST I WRITE IF FOR EXAMPLE I WANT TO BUY 100000 EUROS(ONE HUNDRED THOUSAND EUUROS). I MUST WRITE 100K OR 100000 OR 100.000 OR 100,000 ?? THANK YOU VERY MUCH |
[2017-04-07 22:46:59] |
This depends upon the particular Forex trading service you are using. In the case of FXCM you would use 100000 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
