Date/Time: Mon, 13 Jan 2025 05:43:41 +0000
Return all windows to original positions from session start?
View Count: 765
[2017-04-07 16:04:21]
trader1 - Posts: 128
I am wondering if I can save all windows so that I can move them around within a session and then click a button and they all return to the original positions I had them in at the start? So, for instance, I open a saved chartbook, then I move the windows around, then later in the session I click a button and all the windows return to their original positions from the start of the session?
Thanks.
[2017-04-07 18:00:13]
The only way to do this is after saving the Chartbook, you need to later close the Chartbook and reopen the Chartbook.
Refer to:
http://www.sierrachart.com/index.php?page=doc/Chartbooks.html
Date Time Of Last Edit: 2017-04-07 20:15:21
[2017-04-07 18:47:21]
So you are saying that when I want to get back to the original state the window layout was in when I first opened it I should close the chartbook without saving and reopen it?
Date Time Of Last Edit: 2017-04-07 18:48:02
[2017-04-07 20:15:42]
Yes.
[2017-04-07 20:33:52]
Okay, but that won't work if I have saved the layout at any time since it was opened, correct?
[2017-04-07 21:06:20]
Yes this is correct.
[2017-04-09 01:48:47]
drywater0 - Posts: 85
Trader1,
I have run into the same situation, and this is my solution. I use "SAVE AS" rather than "SAVE" and just make a different version of the workbook after moving the windows around. For example, open Workbook called "My ES Charts", move the windows around and then SAVE AS "My ES Charts - v2". Then you can easily have access to both the new and old format. Hope this helps.
