Date/Time: Mon, 13 Jan 2025 05:16:36 +0000
Ultra T-Bond Symbol
View Count: 1287
[2017-04-07 14:53:48] |
User636679 - Posts: 32 |
Symbol for Ultra T-Bond is UD and UL for (Pit). I attempted to look up both symbols and neither was recognized. Please advise. Thank you, Bryan |
[2017-04-07 17:49:26] |
We see you are using IQ Feed. So you want to chart these symbols with IQ Feed? Refer to: http://www.sierrachart.com/index.php?page=doc/DTNIQFeed.html#Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-07 19:18:31] |
That didn't help - at all. What's the problem with using IQ feed - it's better than using CQG Continuum. Will you help me with my problem? The symbols (UD, UL) don't work.
[2017-04-07 22:51:55] |
There is no problem with IQ Feed. We never meant there is any issue with that. UD, UL without a month or year are just considered stock symbols. You need to look up symbols and this is explained right here: http://www.sierrachart.com/index.php?page=doc/DTNIQFeed.html#Symbols (Symbols) We are going to look up the ultra T-bond future symbol for IQ Feed and add it to the list. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-08 14:19:37] |
Will you let me know when it's been added to the IQ Feed list? Thank you, Bryan |
[2017-04-08 14:21:00] |
Never mind - I see it's been added. Thank you very much, Bryan |
