Date/Time: Mon, 13 Jan 2025 05:34:08 +0000
Alert/indicator request
View Count: 1133
[2017-04-07 09:07:33] |
EuropeanTrader - Posts: 290 |
Hello, how can I "color bar" green IF: price (last) is above upper Keltner channel at the same time when chosen oscilator (Macd fast line)makes a new 30 bar high value. Vice versa for short side. How can I do that please? Thank you! |
[2017-04-07 17:40:29] |
This can be done with the Color Bar Based on Alert Condition study: http://www.sierrachart.com/index.php?page=doc/ColorBarBasedOnAlertCondition.php For this: (Macd fast line)makes a new 30 bar high value.
Use this study to help identify this: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s54 (Highest High/Lowest Low Over N Bars) You will want to base it on the MACD study: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-08 08:32:48] |
Yes, thank you, I did all this so far. I just don't know how to write an alert for that on one sentence. If anyone can do it, help is greatly appreciated. Thank you. |
