Date/Time: Mon, 13 Jan 2025 05:14:13 +0000
User Question
View Count: 652
[2017-04-06 19:13:07] |
Sierra Chart - Max - Posts: 5778 |
Is this possible? See attached
How do I seperate the 30 Min letters so each 30 min time shows in its own column? I want each letter to be in a column by itself. Sierra Chart Support |
Mkt Prof Sierra Chart.jpg / V - Attached On 2017-04-06 19:13:01 UTC - Size: 202.92 KB - 267 views |
[2017-04-06 20:54:57] |
Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#TPOBlocksOwnColumn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
