Date/Time: Mon, 13 Jan 2025 05:28:03 +0000
1522 Issue with Files to Open on Startup
View Count: 617
[2017-04-06 18:41:25] |
infpz - Posts: 826 |
Global Settings > General Settings > Files to Open on Startup I am putting the files in a correct order - hitting apply. When I log back in, the files are mixed up again and opening in the incorrect order as a result. Any idea why? |
[2017-04-06 19:15:16] |
We would not expect there to be any problem in that version. Update to the current version. However we want you to disable Global Settings>> General Settings >> Accept Server-Side Set Startup Files. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
