Date/Time: Mon, 13 Jan 2025 05:32:35 +0000
SC code
View Count: 646
[2017-04-06 16:52:20]
User28682 - Posts: 233
Hi, I would like to modify a study you have, OBV. Is it possible to see the code for it to make this easier since I am new to programming with SC?
Tom
[2017-04-06 19:38:19]
Sierra Chart - Max - Posts: 5778
If you are referring to the On Balance Volume study, you can find the source code within the C:\SierraChart\ACS_Source\studies7.cpp file, assuming that you have installed Sierra Chart in the default folder (C:\SierraChart\). The function name is: scsf_OnBalanceVolume
For more information, refer to the Searching for Source Code for Sierra Chart Built-In Studies section here:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn
Sierra Chart Support
[2017-04-06 20:19:03]
Yes this is available.
Refer to:
http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn
If you need help contact Jim _AT_ SierraChart.com. However, his services are not free and they have a cost.
