Date/Time: Mon, 13 Jan 2025 05:44:19 +0000
6E chart trade display showing wrong p/l with gain data feed
View Count: 643
[2017-04-06 15:18:28]
User902167 - Posts: 31
i have issue with chart trader showing wrong p/l , for example when using measuring tool the ticks on chart display right, but when viewing trade window on chart the net p/l should show 16 ticks instead it shows .00080P. I sent a screenshot also. Thanks.
imageScreenshot - 4_6_2017 , 11_10_09 AM.png / V - Attached On 2017-04-06 15:17:53 UTC - Size: 257.94 KB - 246 views
[2017-04-06 20:22:43]
Refer to this section here:
http://www.sierrachart.com/index.php?page=doc/ProfitLossCalculationsAndSymbolSettings.php
You just need to change the Profit/Loss format.
[2017-04-06 20:38:48]
I have looked everywhere except that, it fixed problem, thanks so much !!
