Date/Time: Mon, 13 Jan 2025 05:18:15 +0000
Study not Updating
View Count: 623
[2017-04-06 13:25:07] |
User28914 - Posts: 87 |
My relative volume indicator doesn't update, even when the market is moving. If I go into Studies and click Apply, it will fill in the missing bars but then not update live again. Thoughts? |
[2017-04-06 16:58:06] |
You need to update to the current version. Refer to: Software Download: Fast Update You should have been receiving an update notice when Sierra Chart is started. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
