Date/Time: Mon, 13 Jan 2025 05:53:27 +0000
study on chart
View Count: 569
[2017-04-06 02:50:11] |
User103949 - Posts: 78 |
Hi, If I apply ACSIL study on different charts in one chartbook, does all the price use only that from the main chart? If i need to apply different study to different product, do I have to use separate chartbook? Thanks |
[2017-04-06 03:39:21] |
We do not understand the first question. You do not need to use a separate Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
