Date/Time: Mon, 13 Jan 2025 05:55:18 +0000
request for DOM
View Count: 785
[2017-04-06 00:55:58] |
User20450 - Posts: 330 |
hey is there any way to add a studies column so we can have important areas plotted on the dom ? thanks in advance
2017-04-05_20-54.jpg / V - Attached On 2017-04-06 00:55:47 UTC - Size: 91.35 KB - 315 views |
[2017-04-06 03:24:13] |
We will see. This would have to be a "Label Column" that could be supported.
[2017-04-06 12:11:44] |
sweet thank you , i think for dom traders its a great feature , let me know if you need me to chip in some cash, thanks for condsidering
