Date/Time: Mon, 13 Jan 2025 05:46:16 +0000
transfer my single licence from my desktop to my laptop
View Count: 608
[2017-04-05 23:09:53] |
User78926 - Posts: 69 |
Hi there, I wish to transfer my single licence from my desktop to my laptop [going overseas for 1 month] so I can work remotely. Can you please tell me how I can do this and also so I can transfer my license back to my desktop from my laptop upon my return? Thanks and reagrds, Mark |
[2017-04-05 23:19:44] |
This concept does not apply to Sierra Chart. You can install Sierra Chart on as many systems as you want and just log in with your Account Name and Password. There is only a limitation on the number of systems you could use Sierra Chart on at the same time. This can also be increased. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
