Date/Time: Mon, 13 Jan 2025 05:08:04 +0000
Trade window
View Count: 586
[2017-04-05 19:08:29] |
GreyLock58 - Posts: 170 |
I can attach trade window to chart, but if I just want to open the trade window nothing appears? Any info? I only want a trade window that I can move to another screen.
[2017-04-05 20:28:33] |
Go to the chart it is associated with and select Chart >> Reset Child Windows and open it again. It will then appear.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-05 20:28:53
