Date/Time: Mon, 13 Jan 2025 05:51:05 +0000
Connection problem with CTS FIX
View Count: 1080
[2017-04-05 12:13:17] |
gretaro - Posts: 3 |
Can you help? I get this error when trying to connect with CTS FIX: Reading Internal Order ID file. | 2017-04-05 11:30:59 Reading Trade Orders file. | 2017-04-05 11:30:59 Reading Trade Positions file. | 2017-04-05 11:30:59 Error binding to UDP port 22903. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-04-05 11:30:59 Software version: 1540 | 2017-04-05 11:30:59 Uses New Spreadsheets | 2017-04-05 11:30:59 Usage end date: 2017-04-25 | 2017-04-05 11:30:59 Enabled for: Advanced Features. | 2017-04-05 11:30:59 Enabled for: Advanced Features 2. | 2017-04-05 11:30:59 Enabled for: Sierra Chart Historical Data Service. | 2017-04-05 11:30:59 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-04-05 11:30:59 Current selected Data/Trading service: CTS T4 FIX | 2017-04-05 11:30:59 Chart Update Interval: 500 | 2017-04-05 11:30:59 Time Zone: +00:00:00 (UTC+00) | 2017-04-05 11:30:59 2017-04-05 11:31:01 Local computer time | 2017-04-05 11:30:59 2017-04-05 11:31:01 Local computer time in UTC | 2017-04-05 11:30:59 2017-04-05 11:31:01 Local computer time in SC Time Zone | 2017-04-05 11:30:59 2017-04-05 11:36:14 Server time in UTC | 2017-04-05 11:30:59 Local computer UTC time and Server UTC time difference: 313 seconds. | 2017-04-05 11:30:59 Notice: Your computer's clock is off by 313 seconds. For help with this, press the 'Send for Analysis' button. | 2017-04-05 11:30:59 Program path: C:\ZenFire\SierraChart\ | 2017-04-05 11:30:59 Data Files path: C:\ZenFire\SierraChart\Data\ | 2017-04-05 11:30:59 OS Version Number: 6.1 | 2017-04-05 11:30:59 Locale Setting: C | 2017-04-05 11:30:59 Checking for new symbol settings for service code cts | 2017-04-05 11:30:59 HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-04-05 11:30:59 Symbol settings are up-to-date for cts | 2017-04-05 11:30:59 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-04-05 11:31:06 CTS T4 FIX | Firm: PTP | 2017-04-05 11:31:06 CTS FIX socket (4) | Creating socket. Using TLS 1.0. | 2017-04-05 11:31:07 HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2017-04-05 11:31:07 HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2017-04-05 11:31:07 HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-04-05 11:31:07 HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-05 11:31:07 HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-04-05 11:31:07 CTS FIX: Sending the Logon message. | 2017-04-05 11:31:07 CTS FIX socket (4) | Received socket Close event | 2017-04-05 11:31:07 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 11:31:07 * CTS FIX socket (4) | Socket gracefully closed by remote side. | 2017-04-05 11:31:07 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-11:36:20.45645=1372=A373=1058=Sending Time Accuracy problem10=191 | 2017-04-05 11:31:07 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 11:31:07 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-11:36:20.45645=1372=A373=1058=Sending Time Accuracy problem10=191 | 2017-04-05 11:31:07 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 11:31:07 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-11:36:20.45658=FIXLogin Time Tag Accuracy Problem - Out of time window10=231 | 2017-04-05 11:31:07 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 11:31:07 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-11:36:20.45658=FIXLogin Time Tag Accuracy Problem - Out of time window10=231 | 2017-04-05 11:31:07 * CTS FIX socket (4) | Initiating close of socket by core. | 2017-04-05 11:31:07 CTS FIX socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-05 11:31:07 CTS FIX socket (4) | Closed. | 2017-04-05 11:31:07 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-04-05 11:31:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-05 11:31:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-05 11:31:07 CTS T4 FIX | Disconnected. | 2017-04-05 11:31:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-05 11:31:07 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-04-05 11:31:10 CTS T4 FIX | Firm: PTP | 2017-04-05 11:31:10 CTS FIX socket (5) | Creating socket. Using TLS 1.0. | 2017-04-05 11:31:10 CTS FIX: Sending the Logon message. | 2017-04-05 11:31:11 CTS FIX socket (5) | Received socket Close event | 2017-04-05 11:31:11 CTS FIX socket (5) | Socket gracefully closed by remote side. | 2017-04-05 11:31:11 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 11:31:11 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-11:36:24.21445=1372=A373=1058=Sending Time Accuracy problem10=187 | 2017-04-05 11:31:11 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 11:31:11 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-11:36:24.21445=1372=A373=1058=Sending Time Accuracy problem10=187 | 2017-04-05 11:31:11 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 11:31:11 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-11:36:24.21458=FIXLogin Time Tag Accuracy Problem - Out of time window10=227 | 2017-04-05 11:31:11 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 11:31:11 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-11:36:24.21458=FIXLogin Time Tag Accuracy Problem - Out of time window10=227 | 2017-04-05 11:31:11 * CTS FIX socket (5) | Initiating close of socket by core. | 2017-04-05 11:31:11 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-04-05 11:31:11 CTS FIX socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-05 11:31:11 CTS FIX socket (5) | Closed. | 2017-04-05 11:31:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-05 11:31:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-05 11:31:11 CTS T4 FIX | Disconnected. | 2017-04-05 11:31:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-05 11:31:11 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-04-05 11:31:14 CTS T4 FIX | Firm: PTP | 2017-04-05 11:31:14 CTS FIX socket (6) | Creating socket. Using TLS 1.0. | 2017-04-05 11:31:14 CTS FIX: Sending the Logon message. | 2017-04-05 11:31:14 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 11:31:15 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-11:36:27.98045=1372=A373=1058=Sending Time Accuracy problem10=200 | 2017-04-05 11:31:15 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 11:31:15 * CTS FIX socket (6) | Socket gracefully closed by remote side. | 2017-04-05 11:31:15 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-11:36:27.98045=1372=A373=1058=Sending Time Accuracy problem10=200 | 2017-04-05 11:31:15 * CTS FIX socket (6) | Received socket Close event | 2017-04-05 11:31:15 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 11:31:15 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-11:36:27.98058=FIXLogin Time Tag Accuracy Problem - Out of time window10=240 | 2017-04-05 11:31:15 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 11:31:15 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-11:36:27.98058=FIXLogin Time Tag Accuracy Problem - Out of time window10=240 | 2017-04-05 11:31:15 * CTS FIX socket (6) | Initiating close of socket by core. | 2017-04-05 11:31:15 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-04-05 11:31:15 CTS FIX socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-05 11:31:15 CTS FIX socket (6) | Closed. | 2017-04-05 11:31:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-05 11:31:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-05 11:31:15 CTS T4 FIX | Disconnected. | 2017-04-05 11:31:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-05 11:31:15 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-04-05 11:31:18 CTS T4 FIX | Firm: PTP | 2017-04-05 11:31:18 CTS FIX socket (7) | Creating socket. Using TLS 1.0. | 2017-04-05 11:31:18 CTS FIX: Sending the Logon message. | 2017-04-05 11:31:18 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 11:31:19 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-11:36:31.91045=1372=A373=1058=Sending Time Accuracy problem10=188 | 2017-04-05 11:31:19 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 11:31:19 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-11:36:31.91045=1372=A373=1058=Sending Time Accuracy problem10=188 | 2017-04-05 11:31:19 * CTS FIX socket (7) | Received socket Close event | 2017-04-05 11:31:19 CTS FIX socket (7) | Socket gracefully closed by remote side. | 2017-04-05 11:31:19 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 11:31:19 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-11:36:31.91058=FIXLogin Time Tag Accuracy Problem - Out of time window10=228 | 2017-04-05 11:31:19 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 11:31:19 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-11:36:31.91058=FIXLogin Time Tag Accuracy Problem - Out of time window10=228 | 2017-04-05 11:31:19 * CTS FIX socket (7) | Initiating close of socket by core. | 2017-04-05 11:31:19 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-04-05 11:31:19 CTS FIX socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-05 11:31:19 CTS FIX socket (7) | Closed. | 2017-04-05 11:31:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-05 11:31:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-05 11:31:19 CTS T4 FIX | Disconnected. | 2017-04-05 11:31:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-05 11:31:19 File >> Disconnect selected. | 2017-04-05 11:31:21 CTS T4 FIX | Disconnected. | 2017-04-05 11:31:21 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-04-05 12:04:53 CTS T4 FIX | Firm: PTP | 2017-04-05 12:04:53 CTS FIX socket (24) | Creating socket. Using TLS 1.0. | 2017-04-05 12:04:53 CTS FIX: Sending the Logon message. | 2017-04-05 12:04:53 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 12:04:54 * CTS FIX socket (24) | Socket gracefully closed by remote side. | 2017-04-05 12:04:54 CTS FIX socket (24) | Received socket Close event | 2017-04-05 12:04:54 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-12:10:09.12045=1372=A373=1058=Sending Time Accuracy problem10=179 | 2017-04-05 12:04:54 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 12:04:54 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-12:10:09.12045=1372=A373=1058=Sending Time Accuracy problem10=179 | 2017-04-05 12:04:54 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 12:04:54 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-12:10:09.12058=FIXLogin Time Tag Accuracy Problem - Out of time window10=219 | 2017-04-05 12:04:54 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 12:04:54 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-12:10:09.12058=FIXLogin Time Tag Accuracy Problem - Out of time window10=219 | 2017-04-05 12:04:54 * CTS FIX socket (24) | Initiating close of socket by core. | 2017-04-05 12:04:54 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-04-05 12:04:54 CTS FIX socket (24) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-05 12:04:54 CTS FIX socket (24) | Closed. | 2017-04-05 12:04:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-05 12:04:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-05 12:04:54 CTS T4 FIX | Disconnected. | 2017-04-05 12:04:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-05 12:04:54 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2017-04-05 12:04:57 CTS T4 FIX | Firm: PTP | 2017-04-05 12:04:57 CTS FIX socket (25) | Creating socket. Using TLS 1.0. | 2017-04-05 12:04:57 CTS FIX: Sending the Logon message. | 2017-04-05 12:04:57 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 12:04:58 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-12:10:12.90945=1372=A373=1058=Sending Time Accuracy problem10=188 | 2017-04-05 12:04:58 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 12:04:58 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20170405-12:10:12.90945=1372=A373=1058=Sending Time Accuracy problem10=188 | 2017-04-05 12:04:58 * CTS FIX socket (25) | Received socket Close event | 2017-04-05 12:04:58 CTS FIX socket (25) | Socket gracefully closed by remote side. | 2017-04-05 12:04:58 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2017-04-05 12:04:58 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-12:10:12.91058=FIXLogin Time Tag Accuracy Problem - Out of time window10=220 | 2017-04-05 12:04:58 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 12:04:58 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-12:10:12.91058=FIXLogin Time Tag Accuracy Problem - Out of time window10=220 | 2017-04-05 12:04:58 * CTS FIX socket (25) | Initiating close of socket by core. | 2017-04-05 12:04:58 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-04-05 12:04:58 CTS FIX socket (25) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-05 12:04:58 CTS FIX socket (25) | Closed. | 2017-04-05 12:04:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-05 12:04:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-05 12:04:58 CTS T4 FIX | Disconnected. | 2017-04-05 12:04:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-05 12:04:58 File >> Disconnect selected. | 2017-04-05 12:05:01 CTS T4 FIX | Disconnected. | 2017-04-05 12:05:01 |
[2017-04-05 16:46:29] |
This is the relevant message: CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2017-04-05 12:04:58 *
FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20170405-12:10:12.91058=FIXLogin Time Tag Accuracy Problem - Out of time window10=220 | 2017-04-05 12:04:58 * Your computer's clock is not set accurately. Refer to help topic 38: http://www.sierrachart.com/index.php?page=doc/helpdetails38.html In regards to this: Error binding to UDP port 22903. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-04-05 11:30:59
Refer to: http://www.sierrachart.com/index.php?page=doc/NewInstance.php#ResolvingDTCProtocolServerPortNumberConflicts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-05 16:53:33
[2017-04-05 16:53:54] |
The prior post has been updated.
