Date/Time: Mon, 13 Jan 2025 05:11:08 +0000
Trade Activity Log and expired contracts
View Count: 591
[2017-04-04 13:35:22] |
User521791 - Posts: 12 |
Hello, how do I see data in the Trade Activity Log for expired contracts? I can only see current contracts in the symbols pulldown menu. Thanks.
[2017-04-04 17:24:51] |
This means that data is not there. Refer to: http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#MissingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-05 06:30:59] |
Got it thanks. How do I combine data/stats for 2 symbols? I'd like to see Trade Statistics for a specific instrument, say NQ, across more than just 3 months period / single contract months.
[2017-04-05 06:46:49] |
You can either select individual symbols. Or All Symbols. Not just 2.
[2017-04-05 07:03:33] |
OK, can you please add this to to a wishlist for future consideration? This feature exists in Multicharts and is quite handy. Thanks.
[2017-04-05 08:00:50] |
This is unlikely. You would not see it for at least two years.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-05 08:01:17
