Date/Time: Mon, 13 Jan 2025 05:26:36 +0000
Gaming Mouse with Sierra Chart
View Count: 1810
[2017-04-04 13:18:11] |
User33743 - Posts: 83 |
Hi, I'm using gaming mouse "Bloody V8M". I would like to ask, how i can configurated some mouse button into Sierra funcionality such as "Crosshair", "Retrecament" or some other. Best REGARDS |
[2017-04-04 16:37:09] |
Sierra Chart - Max - Posts: 5778 |
You would need to make sure that there are Keyboard Shortcuts set for the menu items that you would like to access: Keyboard Shortcuts for Menu Commands And then map those keyboard shortcuts to the buttons on your mouse, you would need to refer to mouse's documentation on how to do the mapping. Sierra Chart Support Date Time Of Last Edit: 2017-04-04 16:46:24
[2017-04-05 12:14:44] |
YEs it works! TY |
