Date/Time: Mon, 13 Jan 2025 05:20:58 +0000
ACSIL - Buy/Sell Exit
View Count: 1062
[2017-04-03 22:18:55] |
jizzary - Posts: 177 |
in reference w/ the functions (in the Title) my understanding is that setting NewOrder's fields: (just for simplicity i refer BuyExit()) OrderId - is required only if there are more than a single open Buy Created positions (then i need to specify which of them should be closed / flattened) in case there is a single open position - then OrderId is NOT required no harm is caused by setting it unconditionaly Quantity - if not used the opn position will be flattened. if quantity is used then only part of the position will be flattened no harm is caused by setting it unconditionaly Is the above understanding true / correct ? tnx Date Time Of Last Edit: 2017-04-03 22:19:52
[2017-04-04 03:21:54] |
In no case would you ever specify the Internal Order ID for a new order. Quantity - if not used the opn position will be flattened. if quantity is used then only part of the position will be flattened no harm is caused by setting it unconditionaly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-04 13:57:58] |
> In no case would you ever specify the Internal Order ID for a new order. my question referred only the xxxExit () functions ... not the xxxEntry() ones) tnx anyway |
[2017-04-04 17:25:20] |
The answer remains the same.
[2017-04-04 18:52:49] |
of course ... no other expectation
