Date/Time: Mon, 13 Jan 2025 05:09:45 +0000
Fit chart in the screen.
View Count: 1096
[2017-04-03 21:08:06] |
fjgaspar - Posts: 62 |
Hi, I have a dayly chart with data from year 2009. I need to fit all available data in the window, and I try to do that by scretching the x-axis or with the Decreasing bar spacing tool. But it comes to a point that it is impossible to reduce more the compression, and to see all data I have to scroll to the left. Is there any way to fit all data in the chart into the window? |
[2017-04-04 03:48:23] |
You need to reduce the spacing between the chart bars. Refer to: Working With Charts: Changing Bar Spacing There is no other way other than increasing the timeframe per chart bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
