Date/Time: Mon, 13 Jan 2025 02:40:12 +0000
Buy/Sell__Entry/Exit functions - return values are not documented
View Count: 597
[2017-04-03 11:08:24] |
jizzary - Posts: 177 |
can u pls explain or point where explained need it urgently tnx |
[2017-04-03 17:59:02] |
Refer to: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html#IgnoredOrderError Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
