Date/Time: Mon, 13 Jan 2025 02:42:57 +0000
Hollow Circle - variable size
View Count: 689
[2017-04-03 10:32:54] |
User132748 - Posts: 159 |
Could you add DRAWSTYLE_HOLLOW_CIRCLE_VARIABLE_SIZE drawstyle same as there is DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE now? Thanks in advance!!!!!!!!!!
[2017-04-03 17:59:40] |
Yes we can do this.
