Date/Time: Mon, 13 Jan 2025 02:56:09 +0000
NUMBERS BAR: HORIZONTAL READING AND DIAGONAL TEXT
View Count: 1280
[2017-04-03 08:28:27]
User993113 - Posts: 74
Hello support,
a colleague sent me this screeshot .
He is using ninja trader with the acme volume impressione indicator by rancho dinero http://www.ranchodinero.com/a7/acme-volume-impression-pack/.
Is possibile in Sierra Charts to achieve the same result?
I need in the same bar to have it coloured red or green by an horizontal reading and, at the same time, to highlight the imbalance in the diagonal dominant side (you can see the gold bold numbers inside the bar). I also need, if possible, to get a greenish or reddish shadow if the imbalanced adjacent cells are 3 or more as you can see in the screenshot.
Thank you
Date Time Of Last Edit: 2019-01-14 13:16:08
[2017-04-03 09:42:40]
binaryduke - Posts: 373
Stacked imbalance highlighting:
https://www.emojitrading.com/stacked-imbalances/
[2017-04-03 18:20:01]
You can do this by relying on both the Background Coloring Method and Text Coloring Method:
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#BackgroundColoringMethods
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#TextColoringMethods
This is not supported.
