Date/Time: Mon, 13 Jan 2025 02:43:29 +0000
Replay Charts and DOM become out of sync
View Count: 1063
[2017-04-03 03:11:02] |
User19165 - Posts: 346 |
When I'm running a replay for an entire chartbook with standard replay option selected, sometimes, data will become out sync from one chart to another. When this is happening, I'm finding that my bid_ask_trade_sync chart will always end up leading the other charts and this problem seems to get more and more exaggerated the longer the replay goes on. Here is a screen shot showing the bid_ask_trade_sync chart leading the other chart and the DOM.
Private File |
[2017-04-03 17:25:53] |
The reason this happens is explained here: http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#SkippingData What we think we might do is add a new Replay Mode called Standard Replay with Multi-day Synchronization. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-03 17:26:22
