Date/Time: Mon, 13 Jan 2025 03:00:38 +0000
Chart values and multiple screens
View Count: 583
[2017-04-03 01:36:35] |
User521791 - Posts: 12 |
Hello, I usually use a laptop connected to multiple screens and have chart values window in an external monitor. When I am traveling and using the laptop only I can bring into focus all detached charts but the Chart Values window (with OHLC values) stays outside my laptop monitor, how do I bring it back into a viewable area? Or is there another easier way to see OHLC data while hovering over a specific candle in the chart?
[2017-04-03 02:43:15] |
You need to select Window >> Reset Windows.
