Date/Time: Mon, 13 Jan 2025 05:26:26 +0000
Custom study - don't execute when chart is recalculating, reloading, anything, ...
View Count: 799
[2017-04-02 11:42:09]
User612903 - Posts: 51
I've got a custom sutdy that works great, but sometime it get's called when I change some chart settings and the chart reload / recalculate.
This is what i have in my code, is there any other line I can use to stop it for running when it's not live.
if (!(sc.ServerConnectionState == SCS_CONNECTED)) {
    sc.AddMessageToLog("NOT CONNECTED", 1);
    return false;
  if (sc.Index == 0) {
    sc.AddMessageToLog("INDEX == 0 ", 1);
    return false;
  if (sc.IsFullRecalculation)//This indicates a study is being recalculated.
    sc.AddMessageToLog("IsFullRecalculation", 1);
    return false;
Thank you very much for your help.
[2017-04-02 19:18:46]
This is all you need to do.
What you have should cover all possibilities.
[2017-04-03 21:35:37]
Okay, unfortunately in my case it's not enough.
For example this is what happened to me last week-end :
- on a chart which does not tick on the week-end, I changed some chart settings
- then i pressed insert to reload and recalculate
And my study got executed.
Anything i missed ?
[2017-04-04 00:16:49]
This can still happen. It can happen because after the full calculation there can still be an update calculation which is done.
You may want to add some code which checks the current time and returns if the market is not open based on the current time. You can use sc.CurrentSystemDateTime
