Date/Time: Mon, 13 Jan 2025 02:58:32 +0000
ACSIL sc.StudyDescription dosen't seem to be working?
View Count: 593
[2017-04-02 08:57:42] |
User553714 - Posts: 184 |
The below ACSIL line doesn't seem to be working; sc.StudyDescription = "Example function for calculating a simple moving average."; When you are in the studies >> Settings window (of the specific custom study) and press "Description," a Notepad window opens an xml looking document full of garble instead of the description inside the quotation marks? Can this be corrected or am I doing something wrong? Regards |
[2017-04-02 10:06:12] |
The file should open within your web browser. Open this file in your web browser and see how it looks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-02 10:16:18] |
As far as I can tell there is no option on how the sc.StudyDescription function displays the data (ie no option on how the file opens?), as a user all I do is press the "Description" button in the studies >> settings dialogue box window displayed. NOTE: This is different to studies >> studies available and hitting the "show study description" which does open the browser and takes you to the SC page of available studies descriptions. Regards |
[2017-04-02 10:37:57] |
You need to associate HTML files with your web browser. How to do that is not within the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-02 11:25:33] |
Thanks for pointer; for others who might search for this. Once the file opens, save the file to the desktop with a name.html (html) extension. Right click on the saved html and press; open with >> choose default programme >> choose web-browser. Regards |
