Date/Time: Mon, 13 Jan 2025 03:00:14 +0000
Trading in the chart - wrong Order placing
View Count: 966
[2017-04-01 13:51:46]
nicktrader - Posts: 727
Most of the time I do use the "Trade Chart mode" to enter Trades. In connection with that I use the Chart Trade Menu.
Most of the time I use Limit Orders and sometimes Stop Orders. In some cases it happens that I set a Limit Order instead of a Stop Orders and vice versa.
The order is filled immediately. Is there a way to avoid that. I'd like to work with 1click Orders only (without any confirmation).
[2017-04-01 22:07:56]
Yes there is a way to avoid that.
Refer to:
Global Trade Settings Windows: Reject Chart Trade Orders That Will Immediately Fill (Global Settings >> Chart Trade Settings >> General >> Order Entry)
[2017-04-02 01:07:18]
Sawtooth - Posts: 4149
There is another way to do a truly one-click chart-trade entry, and always with the correct order type:
1) Use the ChartDOM
2) Uncheck all confirmations
3) Set the ChartDOM settings as in the pic.
imageChartDOM settings.png / V - Attached On 2017-04-02 01:04:31 UTC - Size: 20.76 KB - 231 views
[2017-04-02 04:01:49]
Many thanks tomgilb but I do not like the ChartDom. I use the same settings for the DOM
