Date/Time: Mon, 13 Jan 2025 02:40:37 +0000
Replay not working
View Count: 2079
[2017-04-01 10:40:58] |
trumpy - Posts: 37 |
Hi - I am attempting to replay intraday charts but it doesn't seem to be working. I have read through the instructions already. The replay control panel appears and I set the speed etc and then hit "play" and then nothing happens. I never get it to actually play and the pause button never appears. I have tried all variations of replay speed and replay methods etc and single charts and all charts in chartbook etc etc. Is there a setting someplace I need to have enabled so this will work? I use the SC data service if that makes a difference. Is there a error log file I can send that might show what is happening? I do not get any errors on the screen once I hit play. Thanks |
[2017-04-01 10:59:02] |
kraizyhorse - Posts: 3 |
I had a similar issue. In my case I had the after hours displayed on my chart. I needed to scroll left to have only the normal trading hour day I wanted to start replaying from on the screen. Once I did that it replayed from that point on, it even replayed the after hours.
[2017-04-01 12:17:51] |
Thanks Krazyhorse that did the trick it works now! Cheers |
[2017-04-02 02:57:32] |
Here are the instructions for replay: Replaying Charts: Basic Chart Replay Instructions It sounds you did not scroll the chart back. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-02 14:14:57] |
No I did. What Krazyhorse posted about having and blank space like weekend data is correct. No need to respond just close the ticket I have it working.
