Date/Time: Mon, 13 Jan 2025 03:02:49 +0000
display
View Count: 590
[2017-04-01 10:36:16] |
kraizyhorse - Posts: 3 |
How do I increase the amount of days displayed on the chart? I'm using Profile and TPO volume Study set. Currently I can only see 5 sessions and then I have to scroll left to see more. Is there a setting to change this? I would like to be able to see much more all on one screen. Thanks |
[2017-04-01 20:34:27] |
You need to reduce the spacing between the chart bars. Refer to: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-02 11:34:53] |
Thanks. I was able to find the answer in the link you provided.
