Date/Time: Mon, 13 Jan 2025 02:37:19 +0000
moving Average rolling high accuracy :really rolling ?
View Count: 1026
[2017-04-01 08:58:42] |
sierra28 - Posts: 120 |
in the capture you can see 2 ma in a 10 mn Time frame chart in green a simple ma 20 in black ma rolling high accuracy 200 mn at the new session the ma rolling is reset and the simple ma is rolling. how to rolle the ma rolling high accuracy ? would it be possible to add others input in the ma rolling high accuracy ? for exemple volume, tick, delta. the interest is that even if we change time frame the ma rolling high accuracy is base of fixe input and not depending of the time frame of the chart. thanks Date Time Of Last Edit: 2017-04-01 09:07:23
Capture.PNG / V - Attached On 2017-04-01 08:58:05 UTC - Size: 31.75 KB - 244 views |
[2017-04-03 04:15:25] |
We are working on this.
