Date/Time: Mon, 13 Jan 2025 02:54:27 +0000
ACSIL - Manual Trading
View Count: 757
[2017-03-31 22:39:26] |
jizzary - Posts: 177 |
as i intentd to manage the trading activity by my own logic (Unmanaged Automated Trading) pls confirm the below is the full list of the required intialized variables needed to be initialized and the required info the list i got from documentation is : AllowMultipleEntriesInSameDirection to TRUE (Yes) AllowOppositeEntryWithOpposingPositionOrOrders to TRUE (Yes) CancelAllOrdersOnEntriesAndReversals to FALSE (No) sc.AllowOnlyOneTradePerBar to FALSE (applies only to ACSIL trading systems) is there is any changes/addition required ? tnx Date Time Of Last Edit: 2017-03-31 23:01:30
[2017-04-01 20:41:59] |
We added another relevant item to the list: Automated Trading Management: Unmanaged Automated Trading Other than that the list is complete. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-01 22:18:16] |
tnx. i need to comment causiosly that is looks problematic does that mean that : 1. documentation is not accurate in relation w/ trading (at other sections) ? 2. the code samples are inaccurate (may cause run time problems) ? |
[2017-04-01 23:18:14] |
1. No. 2. No. The Maximum Position allowed variable is not part of the primary controlling automated trading logic. It is secondary and still applies to unmanaged automated trading. It is only mentioned now in the Unmanaged Automated Trading section for completeness. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-01 23:27:41
