Date/Time: Mon, 13 Jan 2025 03:02:51 +0000
Package 5 AMP
View Count: 1642
[2017-03-31 21:23:44] |
User794640 - Posts: 33 |
I'm currently on a non direct account package 3 through AMP. I'm evaluating package 5 currently and plan to upgrade to package 5 when my eval runs out (in about a week). Amp charges me X dollars to get package 5 through them. I need to be able to install Sierra Chart, on the same machine, at least 1 different instance and ALSO on at least one secondary machine. If I am paying through AMP for package 5, can I install multiple copies on same machine and also be logged in under a different computer? What features would I be limited by going through amp and not a direct account? The only reason I like going through AMP is payments just come out automatically from my trading account and it makes it one less thing I have to think about but if I need to establish a direct account for the features I need, it's no big deal. Thanks in advance.
Date Time Of Last Edit: 2017-03-31 21:24:42
[2017-04-01 01:15:51] |
If I am paying through AMP for package 5, can I install multiple copies on same machine and also be logged in under a different computer? Yes you can but you may not be able to connect to the external trading service at the same time. You will need to contact AMP related to that restriction.What features would I be limited by going through amp and not a direct account? The only restriction is just that you can connect only to your AMP trading account.For example you would not be able to connect to Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
