Date/Time: Mon, 13 Jan 2025 02:47:00 +0000
Ignored signals, new bar at session start
View Count: 573
[2017-03-31 16:58:35] |
JamesP - Posts: 89 |
When I check new bar at session start I'm getting a "spreadsheet order signal has been ignored because auto trading has been disabled" message even though the trade is not in an excluded time period in cell J28. When I uncheck "new bar at session start" the same trade fires off per usual in market replay.
[2017-03-31 17:22:24] |
You need to check your formula which we have no idea what it is and it is not within the scope of our support to provide formula programming help. The issue must be with the formula. Refer to: https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#DisableAutoTrading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-31 17:23:23
[2017-03-31 18:17:16] |
I have run the formula through a hundred replays and it's fine, as soon as I switch to start new bar at session start it doesn't work(using range bars on ES). If it isn't the formula is there anything else it could be? Thanks.
[2017-03-31 18:33:29] |
We cannot even begin to comment on this because we have absolutely no idea what the formula is to begin with. And the only possibility is with the formula itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-31 18:33:45
