Date/Time: Mon, 13 Jan 2025 02:37:41 +0000
Vol at Price Threshold Alert V2
View Count: 671
[2017-03-31 02:59:52] |
User104854 - Posts: 457 |
Hi. I use this indicator for a number of things. It looks like by default it always shows the draw style indicator on the bid price. I use diagonal imbalances and there are times when I'd like to have it show up on the ask price. Can you please make this an option? Or perhaps an option to displace the indicator up or down along the bar just like the offset option allows you to move it to previous bars or future bars? Or maybe a simple option to 'display on ask or bid price' would be great. Whatever works. If there is currently a way to do this now please let me know. Otherwise, please get back to me on this. Thank you. |
[2017-03-31 03:39:06] |
We can put you in contact with a programmer who can make the necessary changes for you for a reasonable cost. Please contact Jim _AT_ SierraChart.com Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-31 14:06:25] |
Ok. I can certainly reach out to him but I've seen many times on here that you've accommodated requests like this for people. You helped me on something awhile back. Can you tell me what constitutes making the adjustment on your end and sending me to a programmer? Have I put in too many support tickets and now you're tired of hearing from me? My intent is not to be confrontational but I don't understand the reason. It seems like a small adjustment to the indicator. Thanks.
[2017-03-31 17:32:13] |
Refer to: Notice: Suggestions (Currently not accepting) Have I put in too many support tickets
Yes it is part of this as well.
[2017-03-31 17:49:54] |
I understand. I think I've found a solution. Good to know that the option is available. Thanks.
