Date/Time: Sat, 28 Sep 2024 08:23:26 +0000
[User Discussion] - Moving Chartbooks over to another computer
View Count: 1948
[2017-03-30 16:18:26] |
User533036 - Posts: 4 |
Hello, Looking to move my chartbook files over to another computer, having issue finding them in my document files or downloads to transmite, would appreciate if someone at Sierra can give me instructions. Thank you |
[2017-03-30 17:39:25] |
Refer to help topic 15: Https://www.sierrachart.com/index.php?page=doc/helpdetails15.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-16 04:53:14] |
User785126 - Posts: 8 |
IM trying to transfer a chart book set up from a PC to a Mac???? Anyone know how.
