Date/Time: Mon, 13 Jan 2025 02:33:40 +0000
Best practice on Data locations for Multiple instances and copies
View Count: 598
[2017-03-29 09:27:50] |
Adam - Posts: 141 |
Hi I currently have 2 Copies of Sierra Chart each with a 2nd instance (4x Sierra Charts Running) They are set like this: C:/SierraChart all data for both the original and C:\SierraChart\SierraChartInstance_2 I have data stored to D:/Data C:/SierraChart2 all data for both the original and C:\SierraChart2\SierraChartInstance_2 I have data stored to D:/Data2 Is this correct or should i be splitting the Data lookup locations for the instances also? or Could i have all 4 SierraChart Copies just referencing D:/Data Thanks |
[2017-03-29 17:38:40] |
Do not share data folders. You are going to have consequences from that which we will not help with. You need four different data folders.
