Date/Time: Mon, 13 Jan 2025 02:00:00 +0000
get Error massage
View Count: 638
[2017-03-28 16:49:22] |
AC84142 - Posts: 9 |
Hi Can't loge on with Rithmic ,get error message DTC bridge has stop working A problem caused the program to stop working I have a good User name and pass word and connecting to my lab top but not to disck tp with windows vista |
[2017-03-28 17:06:01] |
Contact your broker and tell them to move you from Rithmic to CQG. Here are the setup instructions for CQG: CQG Trading Platform Service: Setup Instructions The problem could be due to Windows Vista but you will not have this issue with CQG. Otherwise, there is no further help we can provide for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
