Date/Time: Mon, 13 Jan 2025 01:59:07 +0000
DTC bridge has stop working
View Count: 700
[2017-03-28 13:24:40] |
AC84142 - Posts: 9 |
Hi Can't loge on with Rithmic ,get Error massage DTC bridge has stop working A problem caused the program to stop working |
[2017-03-28 16:19:44] |
Contact your broker and have them move you to CQG from Rithmic. We recommend that you use CQG rather than Rithmic. Here are the CQG setup instructions: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
